mid year rear spring parts - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2161
    Does any one have a original rear leaf spring that is good only for parts? I need the top leaf for a 66 BB. Thanks
  • Russ S.
    • April 30, 1982
    • 2161
    Re: mid year rear spring parts
    Any one know where I can find one? Who deals in salvage vettes?
    • Ronald L.
      • October 18, 2009
      • 3248
      Russ, More like salvage parts, F41 or regular suspension?
      • Russ S.
        • April 30, 1982
        • 2161
        This is needed for a regular suspension. Thanks
          Russ -
          Just to clarify, all 66's with standard suspension used the 9-leaf 2-stage spring with all three top leaves flat; the F41 spring had seven leaves, all of which were cambered. Do you need the flat one?
          • Russ S.
            • April 30, 1982
            • 2161
            John. It is the 9 leaf std spring with the flat leaf. Top leaf. Tks
            • Michael G.
              • January 1, 1997
              • 1251
              One more thing Russ, same 9 leaf spring was used for small and big block engines.
                Russ -
                You might try Paragon Vintage - they have piles of old used rear springs out back.
                • Tom L.
                  • October 17, 2006
                  • 1439
                  Russ, I have an old spring that had a cracked leaf. The top leaf is not cracked but one end is a bit corroded. You're welcome to it if you want it. Let me know.
                  Tom
                  • Russ S.
                    • April 30, 1982
                    • 2161
                    Thanks Tom and the rest of you for the help.
