Brake Squeek - NCRS Discussion Boards
Brake Squeek
  • Paul L.
    • August 9, 2011
    • 39
    Brake Squeek
    My 1966 Coupe has disc brakes and they squeek at every stop.
    I see that there are kits that add some plastic to the edges of the pads. Does anyone have any experience with using this remedy. If not, what other options are out there to stop this annoying squeal/squeek.
  • Domenic T.
    • January 29, 2010
    • 2452
    Re: Brake Squeek
    Paul,
    I use silicone gasket you get in tubes, it's the same as they give you when you replace the pads.
    A little between the piston and back of the pad will do it.
    Many will tell you to get them turned but you can only do that so many times and then you replace parts.
    If you think your discs are glazed you can sand them to break the glaze.
    I have a brake lathe here and only use it for legal reasons as it is not necessary to turn drums and discs all the time.
    DOM
    • Jeffrey S.
      • May 31, 1988
      • 1879
      Re: Brake Squeek
      Paul,
      For years I used thin "U" shaped plastic located at the front of the caliper between the metal backing of the pads and the caliper on my '69. This seemed to work well and then I was told to use organic pads (as opposed to semi-metallic) and put a chamfer at the leading and trailing edges of the pads. I did this and when I removed the plastic to try it the brakes were absolutely silent. I have no idea why but there is no squeaking. FWIW.
      Jeff
      • George C.
        • November 1, 2001
        • 568
        Re: Brake Squeek
        Paul,
        I have used the little plastic inserts on my 65 and they worked for me!!
        George
        • Paul L.
          • August 9, 2011
          • 39
          Re: Brake Squeek
          Thanks for the information. I will try the "brake Plastic" and hop that that does the trick.
          Thanks again.
          Paul
          • Paul L.
            • August 9, 2011
            • 39
            Re: Brake Squeek
            Originally posted by Domenic Tallarita (51287)
            Paul,
            DOM
            What are legal reasons for the lathe? I am confused.
            Paul
            • Domenic T.
              • January 29, 2010
              • 2452
              Re: Brake Squeek
              Paul
              Paul,
              In some accidents where the person driving says their brakes failed, they go after the shop that did them and ask why certain things were not done.
              All shops turn the drums & discs along with other things to do a complete brake job. If they skip any item that could add to the safety of the job they can be liable.
              I was told years ago when I worked for a dealer that we had to do a complete brake job because they were sued for only repairing part of the brake system after inspecting the brakes.
              DOM
              • Ronald L.
                • October 18, 2009
                • 3248
                Re: Brake Squeek
                Brake squeal at the OE level is usually fixed by one of two solutions:
                1. Pad composition. While the organic versus semi metallic or ceramic pads usually won't squeak, they can melt to the rotors on hard braking, where a hard stop is defined by emergency lockup; and it only takes one time to do it. I've had it happen for those nay sayers out there. I can't post the trade secret the OE's generally use as far a pads that solve this, but they are not available for a c2 c3 from that MFG anyway. They work perfect to solve the issue with any other common car or truck.
                2. The brake grease. That comes in the brake pad kits. Or purchased separately, you want to get a thin smear on the piston, and, any other contact edge where the pad is rubbing on the caliper.
                Get it on the rotor and you're not stopping very good. Any other gimics out there I'd not try since they were not tested for safety by the OE.
                • Wayne W.
                  • April 30, 1982
                  • 3605
                  Re: Brake Squeek
                  Paul,
                  DOM
                  I would never use anything like this silicone between the piston and the pad. The pad is designed to shift when applied, and anything that sticks the piston to the backing will cause twist of the piston. Continuous twisting of the pad wears the piston and the seals and causes premature failure. Even sticky sprays and soft backing on some pads will do the same. Just dont do it.
                  • Wayne W.
                    • April 30, 1982
                    • 3605
                    Re: Brake Squeek
                    Paul,
                    DOM
                    Sounds like the dealer was giving you the company line they tell customers in order to boost profits.
                    The fact is, if you have worked on the brakes and they go out and fail causing a crash, you are going to be sued anyway. No matter what you did to them, full repair or otherwise.
                    • Domenic T.
                      • January 29, 2010
                      • 2452
                      Re: Brake Squeek
                      Wayne,
                      That is what ALL the brake pads come with.
                      It does't stick the piston to the pad, it stops the cricket type vibration like when a cricket rubs it's wings together.
                      The pressure at the piston to pad is much to high to let them stick together.
                      You can use the little pack they give you for as gasket sealer as it is the same.
                      It's silicone, just like the stuff that is used for gaskets.
                      DOM
                      • Wayne W.
                        • April 30, 1982
                        • 3605
                        Re: Brake Squeek
                        Wayne,
                        DOM
                        No matter what comes with the pads, it aint good to use it.
                        • Domenic T.
                          • January 29, 2010
                          • 2452
                          Re: Brake Squeek
                          Yes,
                          You are right, it isn't the best way to do it.
                          I didn't do it to my 67 vette because it's a sloppy cure.
                          I will take the time to do it right on the vette but when it comes to the passenger car, then I do it like they want BuBa to do it.
                          DOM
                          • Wayne W.
                            • April 30, 1982
                            • 3605
                            Re: Brake Squeek
                            Yes,
                            DOM
                            Most passenger cars have a different design, and the pad is retained anyway. It probably wont hurt anything on them.
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              Re: Brake Squeek
                              Wayne, while the general auto parts stores sell this stuff, the OE's use it too. It a tube of it is in all the really good pad sets I've seen over the last few years.
                              From the nature of this, it also has graphite, at least that what's I got from the OE engineer. I will say DOM is correct, silicone grease - if you use regular grease on the floating pins of these modern designs, that oil in the grease will swell the o-rings and your braking system will be SOL, pin locks up, does not float, pad jammed on the caliper and a short life of the pad & rotor begins, or ends, depending upon how you look at it.
