I've got a '65 FI car with the original 380 unit. The car runs very strong, Idles well, doesn't breakup at high rpm's (I don't run it to redline though). I installed new plugs about 250 miles ago, pulled 4 out yesterday and to my surprise the insulators were still white. I would think that if this motor was running that lean it wouldn't run like it does. So my question: Does the economy stop
position or adjustment affect the running mixture of this motor? If so then what direction do I need to go to richen this thing up? If this isn't the issue then suggestions.
Thanks, Blake
Thanks, Blake
If you screw the economy stop in so that the end of the screw goes back toward the firewall then you are richening it. I run 114 leaded race gas in the race car and I monitor the A/F ratio continually. It runs an A/F of around 13.8 to 14 on idle and 12.5 to 12.8 under load. My plugs don't get very much discoloration even in race conditions. My FI unit has been modified for racing but yours will do the same. They are very reliable and steady when set up properly. I would resist the urge to twiddle.
