At Carlisle this year I purchased a new soft weatherstrip for the decklid on my 67 convertible. The stiff GM rubber never let the lid sit flush so I removed it to install the new soft rubber. The lid sits high in the center peak line and there is currently what looks like a 1/32" shim on each front bolt.
After looking at my 67 AIM a 3755670 shim (8 REQD) is called out and this is different then the (AS REQD) spec in other AIM's. Can anyone tell me what this shim looks like because the thin shim that's there now looks like a front end shim.
My 1963 AIM shows this shim as the same part # as the hinge assembly shim but I think the bolt is larger so that can't be correct. Looks like I need a larger shim in the front bolt position to change the angle some.
