1967 AIM: old style Fuel Pump 6440083 for cars with C60 and/or L79?? (C60-C2, L79-A2) - NCRS Discussion Boards
    Re: 1967 AIM: old style Fuel Pump 6440083 for cars with C60 and/or L79?? (C60-C2, L79
    Originally posted by Scott Smith (50839)
    I think I have figured out most of the other associated parts for a 1967 Corvette with L79 and/or C60, but not sure about this one:
    3855858 Pipe Asm.
    This part number I have not found in any of the AIMs, and I did not see it in any of the P&As. I suspect it is a Production Only part number for the small block high performance fuel line from the Carburetor to the Fuel Pump, without external fuel filter.
    If so, I think the GM Service Replacement p/n is 3882837. This part number is applicable for 1966-1968 Corvette w/Sp. H/Per. (327).
    Is this correct?
    Must be another P&A error - that line works for '66-'67 L-79's (both had Holleys with the same downward-facing primary fuel bowl inlet), but it won't work for a '68 - they had Q-Jets.
    • Scott S.
      • September 11, 2009
      • 1961
      John,
      I forgot about the Quadra-jets.
      The 1967 and 1968 P&A's both say:
      66-67 CORVETTE w/Sp. H/Per. (327) . . . . . . carb. gas (chrome) . . . . . . 3882837
      It is not until the 1969 P&A that the error begins:
      66-68 CORVETTE w/Sp. H/Per. (327) . . . . . . carb. gas (chrome) . . . . . . 3882837
      I suspect this CHROME fuel line is going to be another bone of contention with the Judges:
      1967 JG:
      "All fuel lines are hot tin dipped formed steel. All metal lines have cadmium dichromate plated steel hex-head male fittings on each end of the line. The main fuel line has a 45 degree bend at the fuel pump end. A one piece hot tin-dipped formed steel line runs from the fuel pump to the carburetor, with cadmium dichromate hex male fittings on each end. The use of Teflon tape is incorrect." (p. 79)
      The 1966 fuel lines were chrome: "The fuel pump to carburetor line and fittings are chrome plated" (1966 JG, p. 114).
      Is there a different carb-to-fuel pump line for 1967 that is hot tin dipped formed steel that will fit between the L79 carburetor and the 6440083 fuel pump? Or do I put the chrome carb-to-pump line on a 1967 L79 (and/or C60) Corvette with the 6440083 fuel pump?
