Value?--'57 997 heads - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Value?--'57 997 heads
    George -
    Slightly different tooling/gaging/part registration system in the machining process between Flint and Tonawanda, like the drilled/tapped front oil gallery and external plug on a Flint block that isn't on a Tonawanda block. Plants were allowed some latitude in process details as long as it didn't affect the compatibility of bolt-on parts.
    on BBC 366 truck engines that drilled and tapped passage into the oil gallery was used to supply oil to the air brake compressor and i wonder if that was the reason for it on the SBC
      Originally posted by Edward Lepelis (22093)
      I have never seen a Tonawanda 997.
      Ed
      Ed -
      I haven't either, but I've seen lots of Tonawanda 539's.
