Ground Straps-'65 - NCRS Discussion Boards
Ground Straps-'65
  • Mike M.
    • July 24, 2011
    • 297
    Ground Straps-'65
    Is their as 'easy' answer on how many electrical ground straps there should be on a radio equipped '65 Coupe. and where they are all located? I know there should be two on the exhaust pipes. One on the throttle bracket? Others? Thanks. Mike
  • Jim D.
    • 2882
    Re: Ground Straps-'65
    It's clearly spelled out in the AIM. If you don't have one, you should.
    • Mike M.
      • July 24, 2011
      • 297
      To tell you honestly I do have one. However I did not have it right in front of me at this moment. I'll look up that information tomorrow.
      • Russ S.
        • April 30, 1982
        • 2161
        Mike, There is also one on the LH front frame to body mount. antenna ground strap by the antenna, and LH motor mount horn to motor.
