63 Rocker Moulding Screws 3830604 - NCRS Discussion Boards
  • Jeff Z.
    • February 1, 1994
    • 94
    Does anyone have pictures of lower rocker sill moulding screw 3830604 which was used both in 63/64. Screws attached rocker moulding to lower birdcage brackets. Archives show this as a SEMS screw however pics have been deleted. 66 AIM shows 9421851 which is a #8 or #10 Phillips pan head with a plain captured washer. Any dimensions of original 63 screws would be also helpful.
    Jeff
    63 Convert 340 hp
    66 Coupe 300 hp
    67 Camaro 1500 hp
    00 SS Camaro 320 hp
  • Jim B.
    • December 1, 2004
    • 54
    Re: 63 Rocker Moulding Screws 3830604
    Jeff--Here is a set of what I believe are original screws. They include the two different SEMS headmarks. The dimension (eyeballing it) from the underside of the washer to the screw tip appears to be right at 5/8". Hope this helps.
    • Rich P.
      • January 12, 2009
      • 1361
      Jim,
      both those are original and the 2 style headmarkings I have seen.
      Rich
