Can anyone confirm the proper testing procedure for a wiper arm control valve? I have connected a vacuum pump to the center port (which normally would come from the wiper solenoid switch). I have plugged the bottom port with a line that has been confirmed to hold vacuum (which normally connects to the wiper actuator). When the spring-loaded valve button is fully compressed (simulating when the wipers are "parked"), theoretically the valve should hold vacuum. If I release the valve, vacuum should be vented via the top port. Is this correct?
Just checking because neither my existing or new "imported" replacement valve are holding vacuum using the above procedure. Both lose vacuum within 5 to 10 seconds. Is it me or the valve???
Thanks!!
Vince
Vince Costa (33415)View Public ProfileSend a private message to Vince Costa (33415)Send email to Vince Costa (33415)Find all posts by Vince Costa (33415)Add Vince Costa (33415) to Your Buddy List
Thanks!!
Vince
