68 A/C Vent Ball Change - NCRS Discussion Boards
  • Cathy S.
    • August 31, 2003
    • 293
    Any advise on how to change the dash vent balls?
  • Terry B.
    • August 31, 1999
    • 607
    Re: 68 A/C Vent Ball Change
    Hi Cathy,
    I had the same problem (my car is not an A/C car but if you are talking about Astro Ventilation vent balls they are the same) and at first I thought I would have to take the dash apart to change my old ones with new ones but with more examination, I just grabbed the old vent ball securely and pulled them out. I pushed the new ones in the hole and they have worked perfectly. Nothing was damaged in doing it this way. I hope this works for you.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Henry J.
      • November 1, 1999
      • 457
      Cathy:
      My experience is the same as Terry's.
      • Michael D.
        • June 30, 1996
        • 536
        I've been told they will come out the front, but have not tried it. I installed my two from the rear because I was too chicken to tug on them.
        • Cathy S.
          • August 31, 2003
          • 293
          Thanks All! Im going in the front
          • Michael D.
            • June 30, 1996
            • 536
            Jeepers. Flipping on to your back in the footwell, wiggling up under the dash, trying to aim the flashlight at something resembling a target while groping around trying to remember where you laid the screwdriver is one of Life's greatest pleasures.
            • Cathy S.
              • August 31, 2003
              • 293
              On your back under a dash in a C1 is not too bad, a C2 is unpleasant, a C3 or god forbid a C4 down right sucks
              • Michael D.
                • June 30, 1996
                • 536
                You nailed the C4 fo' sho'. Been there, tried to do that.
                • Dale C.
                  • November 1, 1999
                  • 844
                  I find it almost worth the effort to remove the seat when going under the dash. It's a good idea to take them out and clean and lube under there anyway. After having the slide bracket (thats welded to the seat) break and not being able to get the seat out, did after extream effort, I like to keep an eye on whats going on under my butt.
                  Dale
                  • Cathy S.
                    • August 31, 2003
                    • 293
                    Finally got the new vent balls. Old one came right out with a 180 twist. Fit is a little snug. They look great. Thanks for the guidance!
                    On to brake caliper install this weekend.
