Hei - NCRS Discussion Boards
Hei
  • William L.
    • July 31, 1987
    • 39
    Hei
    First this is a HEI question for the truck I'm working on and if you choose you can deleate it. Here goes - I installed a HEI in my 1969 GMC truck - runs great BUT in doing the wiring I removed the pink wire from the ignition switch ( for a dedicated 12 Volt source - start & run) & now the Alt. is not charging. I must reconnect that PINK wire - but where ??Thank you. Bill Lehmann 11787
  • Terry D.
    • May 31, 1987
    • 2690
    Re: Hei
    William
    Call Mark at M.A.D. Electric (559-539-7128). Man is a wizard, hard to get a hold of but will definitly have a answer for you.
    • Jim T.
      • March 1, 1993
      • 5351
      Re: Hei
      William one easy way in my opinion is to make up a wire with appropiate terminals and connect one terminal to the IGN on your 69's fuse block and the other to the HEI and start it up.
