Re: '69 L36 Suspension Options
Floyd one place to look to see if the 69 had originally had under the car exhaust is at the frame crossmember for the transmission mount. If the exhaust pipe attachment brace is still installed on this 69 it is unlikely that it left the factory with side exhaust since this brace is not required except in under the car exhaust pipes.
The pictures do not show the rear lower license plate area. Panels years ago could be purchased to replace the rear lower panel to replace the panel installed at the factory that had the exhaust outlet provision for under the car exhaust systems.
Until about 23 years ago I had the 69 side exhaust system installed on my 1970. Changing back to under the car exhaust I did not go back to original factory installed type under the car exhaust pipes. I installed the larger 2 1/2 inch exhaust pipes that were available on 1968 Corvettes. I also changed the 2 inch exhaust pipe bracket on the transmission mount to the earlier 2 1/2 exhaust pipe bracket.
Windshield frame rust underneath the stainless trim has been a problem on C3's.
