Re: Accelerator Rod
Tim;
What I don't understand is why I have slightly different adjustments from one AFB to another, i.e. 3461S vs. 3731SB. They seem to measure the same from center of primary throttle shaft to center of throttle rod hole. But there are subtle differences because I can not use the same number of idle screw turns to get the same idle speed, same goes for the two mixture screws. It can't all be the idle tube jets, can it? (.035" vs. .037").
I've found out a number of other unique characteristics of the 3461S I'll share with you in a PM soon.
Stu Fox
Tim;
Stu Fox
