Top Ignition Shield Repair Kit - Plastic Rivet - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    One of the plastic rivets on my top shielding feel off this week. I ordered a kit from CC and now have some of the plastic rivets and metal washers, but there are no instructions on how to melt or crush the plastic rivet over the washer to hold the inner protector in place. Anyone done this and have a suggestion? I tried heating with a solder iron but no luck. Thanks.
    Kirk
  • Kirk M.
    • June 30, 2006
    • 1036
    Re: Top Ignition Shield Repair Kit - Plastic Rivet
    Yikes, no one knows how to do this?
    Kirk
    • William C.
      • July 15, 2009
      • 239
      Kirk..I used a soldering iron and it worked fine. Your iron isn't hot enough..Bill
      • Chris G.
        • August 12, 2007
        • 44
        Kirk, could you post the CC part number for these plastic rivets and washer reapir kit? I have been looking for something like this for while and cannot find it online at Corvette Central. Thanks
        White 1970 LS5 390/454
        • Steve D.
          • May 16, 2011
          • 106
          Are they the clear yellowed or white rivets?
          • Kirk M.
            • June 30, 2006
            • 1036
            CC 472021 Top Shield Repair Kit. They are white in color.
            I used one of those grill starters and flamed the rivet once mounted. It lit sorta like a candle wick and then I crushed it with one of my airplane rivet gun tools into a rounded shape. Kinda scary with open flame inside top cover, but I just lit it several times in a row until the rivet caught fire than crushed it. No heat damage to anything else around it.
            Kirk
