1968 Door Handles - NCRS Discussion Boards
1968 Door Handles
  • Mark D.
    • June 30, 1988
    • 2142
    1968 Door Handles
    The 68/69 TIM & JG revision team members would like to thank all the 68 convertible owners for your recent help regarding under dash braces.It has been most helpfull so, again, thank you.
    Now we have one more question for ALL 1968 owners (coupes and convertibles).
    Thanks in advance for your help.
    Kramden
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1968 Door Handles
    Hi Mark,
    My Dec '67 (E08) build car has type # 2 door handle.
    My driver side handle broke about 10 years ago but I still have it. The passenger side handle most likely is more reliable on the survey as it was not used as much and probably survived without replacement.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Jack C.
      • September 30, 1992
      • 1090
      Mark. The #1's are on my Jan 22 (9643) built car. My guess is that #2 is the earliest, #1 is next and #3 is late.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
      • Daniel S.
        • February 1, 2000
        • 164
        #1 and the one on the drivers side door recently broke. Lasted 40 plus years but somehow that doesn't ease the pain.
        April 29th build
        • Reba W.
          • 932
          You are lucky, Daniel. That is the one that we have found was the weak design and most often replaced.
          • Jim T.
            • March 1, 1993
            • 5351
            1968 original owner 2/19 date on trim tag with door handle #1.
            • Gene M.
              • April 1, 1985
              • 4232
              #2, built Nov 67
                Mark------
                Are there any embossed numbers to be seen anywhere on the #1 and #2 handles? It appears that at least the #1 has some sort of embossment but I can't discern it in the photo.
                • Dick W.
                  • 10483
                  Mark------
                  Joe, I see ??404 on the first one. I believe that the GM service #'s ended in 693 and 694?
                  Dick Whittington
                    Dick-----
                    The '693' and '694' were the 3rd design handles. However, '404' does not work for either the 1st or 2nd design part numbers
                    • Dick W.
                      • 10483
                      Dick-----
                      I enlarged the photo 500% and it looks like the last four may be a one??
                      Dick Whittington
                      • Mark D.
                        • June 30, 1988
                        • 2142
                        Joe,
                        I'm not sure where the pic originated. It may have been Bill Vyn or Terry Buchanan. Reba might know.
                        Mark
                        Kramden
                        • Terry B.
                          • August 31, 1999
                          • 607
                          Mark------
                          Joe,
                          On style #1, I have seen two number, 68405 and 68404. Perhaps this is the difference in right and left handle.
                          On style #2, the number is 68404 and there is no other numbers on the handle. It also has L or R on the inside base.
                          The pictures that Mark posted are not mine.
                          Terry Buchanan
                          Corvettes Owned:
                          1977 Coupe
                            Originally posted by Terry Buchanan (32872)
                            Joe,
                            Terry-----
                            They must be manufacturer's part or ID numbers since they do not represent GM part numbers nor are they a derivative of any 68-69 GM part number that I've been able to find.
                            Curiously, there were 3 sets of part numbers used for the door handles over the 1968-69 period, exactly as many sets as there are examples in the photograph. Based upon what I do know and what's been reported by 1968 owners so far, I'd say it's like this:
                            style #2= GM #3922017, 3922018
                            style #1= GM #3942715, 3942716
                            style #3= GM #3962693, 3962694
                            I do not think that style #3 was ever originally used on any 1968 Corvette but I would not completely rule it out for very late cars.
                            • Brian W.
                              • September 30, 1990
                              • 216
                              My Dec.'67 (E) convertible both handles are #2. One has cast 68404 R and a C within a triangle. The other one is 68405 L also a C within a triangle.
                              Brian
