C1 Frame Primer? 1960 - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1338
    Was the frame dipped in primer before it was dipped in black paint?
    I removed the paint off of the rear crossmember today and there was white paint under the black paint; equal parts paint and rust.
    What type of tool is good to remove rust in tight places? I want something that removes it faster than naval jelly.
    I used my 4 inch grinder with a wire disk, but there are smaller areas I could not get to. I have a standard dremel, but I believe it is too weak to do the job. I don't have a large air compressor, but could borrow my neighbors and purchase some type of air tool. Suggestions?
    Re: C1 Frame Primer? 1960
    Joe -
    Per our old friend Dale Pearman's notes, the C1 frames (made at A.O. Smith-Milwaukee) were acid-dipped first to clean them, then dipped in a neutralizing solution, then dipped in self-etching black frame primer (DuPont #475-763) and baked. No further painting was done.
    • Joe M.
      • April 30, 1990
      • 1338
      Thanks John. The white underpaint is another example of someone's attempt at restoration back in 1979 as that was when my car was repainted. The painter placed a small orange adhesive label on the underside of the gas cap / vent hose lid that said "painted by Jerry Daniels, 1979." I purchased the car in 1960.
