1971 LT-1 car will not idle below 1100 rpm most of the time about 1500 rpm when it idles down eventually after the car is driven for 20-30 minutes it will go down to 700rpm and stall out. Just had the Holley carb rebuilt. Checked the vacuum lines they all look good. Could it be the TI and is there a way to test it. What about the TCS where is that valve located and how can you test that for vacuum leaks? There is a vacuum valve inside the passenger front fender under the windshield washer container what does that valve do? The headlight and wiper vacuum works good. The car also hesitates a little during acceleration like a flat spot.
