C2 Bumper Braces 66 & 67 - NCRS Discussion Boards
  • Ronald L.
    • October 18, 2009
    • 3248
    Has anyone noted the difference in these two front C2 bumper braces - that is the one lower corner is chopped off at an angle?
    The top one - with the correct factory 'D' I think is 67 only.
    The lower 66 and prior model years.
    What do you guys have on your original cars???
  • Russ S.
    • April 30, 1982
    • 2161
    Re: C2 Bumper Braces 66 & 67
    My originals from my 66 have the corner cut off.
      June '67 - corner cut off.
      • Ronald L.
        • October 18, 2009
        • 3248
        Russ, is your car a very late June July 66 production?
        The part number did not change in 1966 3848217 - 8.
        • Scott S.
          • September 11, 2009
          • 1961
          Ron,
          Corners are cut on Jan. 11, 1967, both stamped "D".
          • Ronald L.
            • October 18, 2009
            • 3248
            Both versions of the original will have the D stamped into them.
            Does any one know why they changed, and when?
            • Bill H.
              • August 8, 2011
              • 439
              Steve, above has cut corners on Jan, 67.
              Working on mine today, no cut - Dec. 27th, 66.
              Not much difference in those dates.
              Pic of them:
              And a pic of the rough finish on the mating bracket.
              • Scott S.
                • 1961
                Pic of them:
                Bill and Ron,
                I should point out that it is possible my RH brace was replaced circa 1971, when the car had right front-end collision damage. Based on the damage discovered with the body off, I don't think there would have been any reason to replace the LH brace, but I don't know for sure.
                Both RH and LH braces have the "D" stamp, and both have the cut corner. They also have a circular stamp that looks like a waffle pattern (picture #2 below). I don't know if early service replacements might have had these markings or not.
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Scott, that is a new twist on this, the originals I have seen were so rusty that that waffle spot would not be visible. I expect that was a keeper so the blank was not sliding around when the metal was bent and punched.
                  • Scott S.
                    • 1961
                    Ron,
                    The same waffle spot is on the other brace, but it's a much lighter stamping (picture 1 below). I also found this same (or very similar) marking on the radiator support (pics 2 and 3).
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Any other thoughts on this, no notch 66 (except perhaps late cars) notches for 67?
                      • Scott S.
                        • 1961
                        What was the purpose of cutting the notch into the end of the brace? Something was probably added or the configuration of an associated part may have changed, requiring a change to the bumper brace.
                        If we figure out what cause led to the change, we might find it in the Revision Record and get a good idea of the approximate date.
                        • Russ S.
                          • April 30, 1982
                          • 2161
                          [quote=Ronald Lovelace (50931);576858]Russ, is your car a very late June July 66 production?
                          The part number did not change in 1966 3848217 - 8.[/quot My build date is March 14th.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            We would need the print to know why the difference.
                            Both were made by the same source and at such a low volume its certain they only had one set of blanking - forming dies for these parts.
                            • Russ S.
                              • April 30, 1982
                              • 2161
                              I have just discovered that my braces aren't the originals as I had thought.I went thru all my many receipts for parts and learned that I had bought new GM ones in 1980. Sorry for the inconveniences I caused. Russ
