Here's a question I'd like to throw out there to all the C-1 guys, at what engine idle speed will your Generator produce enough juice to show a charge with all the lights ect... on (under load) assuming you have a healthy electrical system?????
I have been running some tests with the newly converted Solid State Voltage regulator and it seems I need a minimum of 850 RPM with the lights on and 700 RPM (daytime) no load to keep the Ammeter at "0". At 1000 RPM, I can run everything the car has and show a positive charge until the battery tops off.
Also, according to the specs, they call for 450RPM idle speed which I have NEVER been able to achieve a decent rate of charge at. Does anyone know why that number is so low??? Did GM mean for these cars to run at a discharge at idle?? TIA
Dan
Dan
Dan
