C1 Top Warning Tag - NCRS Discussion Boards
C1 Top Warning Tag
  • Gary L.
    • June 19, 2011
    • 62
    C1 Top Warning Tag
    Has Anyone Replaced The Warning Tag On A Convertible Top? I Have The One With The Thread Sewn Onto The Tag. Need Advise On How To Do This.
  • Gary B.
    • September 30, 1987
    • 305
    Re: C1 Top Warning Tag
    I have seen for judging purposes a few years ago.
    Take the NEW tag and sew stitches through it to match the stitching on your present top. And at the Event "Back to Back" tape the tag it it's proper position. I have also seen the tag wrapped in "Saran Wrap" to protect it.
    Practice your stitching on old business cards.
    • Gary L.
      • June 19, 2011
      • 62
      Thanks For The Advise. I Do Need To Practice My Sewing Skills First.
        Gary -
        Is there a setting on whatever software you're using to turn off the feature that capitalizes the first letter in every word you type? It makes your posts difficult to read.
        • Gary L.
          • June 19, 2011
          • 62
          yes---cap locks!
          • Gary B.
            • 305
            Gary -
            John: I do not see this on my Monitor.
              Gary -
              Oops, two Garys. I was referring to Gary Locklin's posts - that anomaly appears in his post #1 and post #3, but not in post #5.
              • Gary L.
                • June 19, 2011
                • 62
                Using two different computers.This is the main one and the other is a laptop. How does this look?
                  Gary -
                  Looks great!
                  • Gary L.
                    • June 19, 2011
                    • 62
                    Found Tags With Thread Sewn Into Tagand Thread Hanging Off Both Ends. Using Sewing Needle And Needle Nose Pliers, I Attached The Tag At Both Ends Going Thru Existing Stitched Holes. Had Plenty Of Thread To Take A Stitch In The Middle Of The Tag To Help Hold It Down Flat. Easy Fix If You Can Get That Dang Thread Thru The Hole In The Needle! Thread Is Exact As Original As Is The Stitching. Looks As Though The Tag Is Sewn On With The Window.
