3yrs ago I had my original non-working '67 clock restored and it worked a treat right up to the exact time of Operations testing for Flight judging in April '10. Yep, no exageration, I couldn't believe it when the second hand stopped ticking only moments before the judge turned to the clock! A quick 'tap' just above the clock got the second hand moving, phew, no deduction and a 97.9% Top Flight.
Anyhoo, for the following 17mths or so the second hand became less & less reliable so I finally decided to do something about it today (by the way, I use a battery isolation switch and drive the car not as frequently as I'd like
). I figured it'd just require some 'lube' so pulled the clock from the dash and jumped on the NCRS Tech Discussion Archives looking for advice (note: no way was I going to send the clock back to the USA all the way from Aussie....cost more in shipping than the service fee!).
I was surprised to read that I shouldn't use WD-40 or similar, only a watchmaker grade lube. Not having any on hand and not wanting to un-crimp the case to expose the mechanism (and likely break something) I went against advice and gave a few small squirts of WD-40 onto the mechanism through the light-globe fitting holes. Well, as soon as I re-connected the clock the second hand jumped into life and hasn't stopped ticking for the last 12hrs!
So, is the clock going to self-destruct after a pre-determined time because I used WD-40?
Cheers, Gary (Perth, Australia)
). I figured it'd just require some 'lube' so pulled the clock from the dash and jumped on the NCRS Tech Discussion Archives looking for advice (note: no way was I going to send the clock back to the USA all the way from Aussie....cost more in shipping than the service fee!). I was surprised to read that I shouldn't use WD-40 or similar, only a watchmaker grade lube. Not having any on hand and not wanting to un-crimp the case to expose the mechanism (and likely break something) I went against advice and gave a few small squirts of WD-40 onto the mechanism through the light-globe fitting holes. Well, as soon as I re-connected the clock the second hand jumped into life and hasn't stopped ticking for the last 12hrs!
