1968 Spring Ring Battery Cables - NCRS Discussion Boards
  • Jeff P.
    • 797
    Morning, I searched for correct cable markings but came up empty. On 68's march build should there just be a P and an N on the top side besides the spring ring words for correct cable heads ? thanks in advanse. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • David L.
    • July 31, 1980
    • 3310
    Re: 1968 Spring Ring Battery Cables
    Jeff,
    I recently sold a pair of NOS GM # 2978482 spring ring ground (negative) cables (30" long) for various 64-70 Pontiac models according to my 1971 Pontiac Parts Catalog.
    The spring ring part was "embossed" with the following: "SPRING", "RING", and "GM" (see photo). The black cable had "DELCO PACKARD - IT30" printed in white.
    The flap on one of the boxes was dated "3-69" (March 1969).
    These cables were service cables and were not necessarily the same as the factory installed cables. I have an original spring ring cable from a 1965 Chevrolet 396 but it looks like it went through a war.
    Dave
    • John C.
      • January 1, 2005
      • 616
      Jeff
      On my April built car the cable only has a P and N on the side with the spring ring text. The text is on the round barrel of head.
      John
      • Jeff P.
        • 797
        Thank you, David and John. Great help. Question for John. On the negative cable do you have 5070 in white ink around 8" from the head ?
        • John C.
          • January 1, 2005
          • 616
          Jeff
          Yes I have 5070 stamped in white ink on the negative cable. It's about 4 inches from the head on my cable.
          John
          • Jeff P.
            • 797
            Thanks John , any clue what it means?
            • David L.
              • July 31, 1980
              • 3310
              Originally posted by John Carlson (43123)
              Jeff
              John
              The number "5070" is the last 4 digits of the GM part number 6295070 (ground cable) as shown in the 1968 AIM (UPC 12, sheet A12). It's not rocket science.
              Dave
              • Jeff P.
                • 797
                Thank you all for your responses.
