C1 Kick Panel - NCRS Discussion Boards
C1 Kick Panel
  • Bob W.
    • August 31, 1981
    • 84
    C1 Kick Panel
    Putting the kick panels back together but I can't figure out how the hide the top of the windlace once the kick panel is installed back on the car that the white tubing doesn't show. Pictures would sure be helpful
  • Stan G.
    • January 1, 1996
    • 106
    Re: C1 Kick Panel
    If you are talking about a C1 it hides behind the dash end cap .
    • Adam S.
      • July 30, 2008
      • 167
      Re: C1 Kick Panel
      If you are talking about 1956 or 1957's the bottom windlace tubing hides under sill plate inner edge, top runs wild & tuched under side of dash ends. 1958,59 & 60 are same on bottom but ,dont know what year you are working on?
      • Bob W.
        • August 31, 1981
        • 84
        Re: C1 Kick Panel
        Working on 1958, I have attached pictures of the end caps but don't understand about putting windlace under them. Also how do I keep the windlace from kinking on the turns? I have cut notches in the back but it still kinks.
        • Adam S.
          • July 30, 2008
          • 167
          Re: C1 Kick Panel
          Bob I see, try heat gun to try to relax it, but not too much as it will blister it. There will be some very slight wrinkles but I don't think they will stay as material shrinks out over a few weeks/monthsI included a pict of pass. side on my 57 when I was test fitting my kicks.
          • Bob W.
            • August 31, 1981
            • 84
            Re: C1 Kick Panel
            Can someone post pictures of how windlass ends on top at bottom of dash pad. 1958
