1967 Vette 427 400 Hp With Factory - NCRS Discussion Boards
  • Steve J.
    • October 2, 2011
    • 3
    Need A Little Help About My Vette It Is A 1967 427 400 Hp With Facory Air This Car Does Not Have The Air Vent In The Middle Of The Dash It Is A Facory Air Car Early Production Could This Be Facory Or Has Someone Chaged The Dash Thanks Steve James
  • Keith B.
    • March 7, 2008
    • 928
    Re: 1967 Vette 427 400 Hp With Factory
    Someone changed the dash or put factory AC in a non factory AC car
    • Steve J.
      • October 2, 2011
      • 3
      IT IS A FACTORY AIR NUMBERS MATCHING WITH THE ORIGNAL WINDOWSTICKER COULD THE FACTORY DONE THIS BY MISTAKE
      • William L.
        • December 1, 1988
        • 944
        Highly unlikely they would let a mistake like that get out of the factory.
        But like they say never say never.
        Bill Lacy
        1998 Indy Pacecar
        • Larry M.
          • January 1, 1992
          • 2688
          Steve:
          I do not believe that this is a factory mistake. I have never seen this before on an original car......early or late production should make no difference. The 1966 and 1967 factory AC dashes are essentially the same, so this would eliminate a year-year changeover issue.
          I don't know what the right answer is, but there are many possibilities. You just need to carefully check the remainder of the car, all AC system components, and AC special construction features to try and arrive at the answer to your question.
          Larry
          • Steve J.
            • October 2, 2011
            • 3
            the last six of the vin is #100983 may be this can help
            • Rich P.
              • January 12, 2009
              • 1361
              Steve,
              post some close up pictures of the dash end tabs and how they are riveted to the body. Might give a clue as to what is going on.
              Rich
              • Robert G.
                • May 31, 1990
                • 429
                Possibly some good news and bad news. The car is listed in the C2 registry as a Canadian export car, so there is documentation available. The bad news is that it's listed as a 390 hp without air. Good luck.
                http://www.c2registry.org/index.php?...=1106&uid=9890
                • Brian M.
                  • February 1, 1997
                  • 1837
                  Is the window sticker real? I smell a rat.
                  • Bob H.
                    • July 31, 2000
                    • 789
                    much more likely someone added air to a non air car. Especially if someone already put it in the registry as a non air car. Adding a tri power is easy enough. Post a copy of the window sticker. There are some telltale signs many can comment on.
                    • Ridge K.
                      • May 31, 2006
                      • 1018
                      Hi, Steve, and welcome to the technical discussion board! I see you're fairly new.
                      Sounds like a great car no matter how this odd dash issue turns out.
                      Do you have the tank sticker......?
                      Ridge
                      • Larry M.
                        • January 1, 1992
                        • 2688
                        Agreed.........but the engine build stamp is different between the two engine configurations.
                        390 HP suffix would be IL (4-spd) or IQ (auto)
                        400 HP suffix would be JC (4-spd) or JD (auto)
                        Larry
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          Steve,
                          Pics of the dash rivets and The engine pad as well as the tri power set up will assist the members here with what you have.
                          What is the status of the car - restored, driver, resto mod?
                          Did the previous owner drop the gas tank - take off the tank sticker? Any mentions of that? Those can be "produced too".
                          Have you purchased the NCRS shipping report? That will confirm the read original dealer and if a Canadian car, I understand all the OE details are available.
                          For better or worse...its still a great car.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            From the C2 registry it shows TI, can a 390 car get TI???
                            The other ting to note is that it is produced 9-15-66... and yet it was imported to Canada Feb 67?
                            That would suggest the original dealer was not Canada, seems a real long time to cross the border.
                            • Joe R.
                              • May 31, 2006
                              • 1822
                              Ron,
                              I believe that TI was available with all engines, mandatory with some.
                              Joe
