68 Battery Compartment Plug - NCRS Discussion Boards
  • Jeff P.
    • 797
    Was looking up under the 68 the other day and noticed that the battery compartment didn't have a plug covering the hole in the bottom middle.
    The jack compartment had the plug. Am I missing a plug or was the battery side like that? Thanks in advance. Jeff
    68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
    2014 Arctic White Z51 Vert. (Wifes)
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: 68 Battery Compartment Plug
    Jeff,
    The drain hole in the battery compartment used a plug that acted as a vent and drain. It allowed any battery gas or acid to be drained from the compartment to the outside. The 1969 AIM shows it in UPC 1 page B1. It lists part number 3948148. I do not have a 1968 AIM. It should be similar.
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
    • Jeff P.
      • 797
      Thank you Lawrence. My 68 a AIM is same UPC 1 and B1. There are two plug numbers though 3948148 and 4725594 . Man I thought I was missing it. The seat plugs look the same as the jack plug.
      • Dale C.
        • November 1, 1999
        • 844
        The 68 and 69 look to have the same plug numbers 4725594 and 3948148. Looks like the addition of 13 (the 3948148) has a revision date of 3-22-68
          Jeff------
          I think that Dr. Rebuild has excellent reproduction of both these plugs if you need them.
          • Jeff P.
            • 797
            Thank you all for great responses . I'm calling them now Joe .
