54 fuel line to carb - NCRS Discussion Boards
  • Lynn L.
    1953-55 Team Leader
    • February 1, 2000
    • 162
    2 of the 3 fuel lines to 54 carbs have compression fittings. Was the compression material rubber? Where can these be purchased? Substitute product? thanks for any recommendations.
  • Chuck G.
    • May 31, 1982
    • 2029
    Re: 54 fuel line to carb
    There are/were rubber washers/gaskets in those 2 fittings you refer to.
    I couldn't find any years ago when I had my 54, so I took rubber fuel hose of the appropriate ID, and cut slices off the end.
    I used those slices as "gaskets". Never leaked a drop.
    Chuck
    • Chris S.
      • January 1, 2000
      • 1064
      I did the same thing
      I could not find O rings that worked correctly
      so I used hose
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Robert K.
        Infrequent User
        • January 1, 2000
        • 29
        I went to an industrial hose supplier and bought some obsolete brass fittings with the same style compression fittings. They looked exactly like short cut-offs of a neoprene fuel line.
