'65 Oil dipstick - oil amount between add & full - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 341
    Hello,
    I'd like to know how many quarts (1?) oil are between add and full on a 327/300 '65 engine and original dip stick. I've never had the oil level reach add.
    Another question: Supposing that the engine overhaul was done properly as well as the breack in (4000 miles ago) how much oil (10W 40) consumption is acceptable under normal driving conditions.
    Regards
    Oliver
  • Jack P.
    • March 19, 2009
    • 1135
    Re: '65 Oil dipstick - oil amount between add & full
    Originally posted by Oliver Schoenhaar (33229)
    Hello,
    I'd like to know how many gallons (0,25?) oil are between add and full on a 327/300 '65 engine and original dip stick. I've never had the oil level reach add.
    Regards
    Oliver
    My 327/350 after a very very very good rebuild and 30,000 miles last year since rebuild burns 1 qt. every 1,300 to 1,500 miles.
    Most of these cars even new used 1 qt between 300 & 500 . The tolerances from the 60's (factory) was not as good as you can get today from a good rebuilder.
    Also , torque of intake bolts and others will affect this along with down shifting for braking.
    Jack
    • Steven S.
      • November 1, 1995
      • 151
      My '63 327- 300hp was rebuilt 10 years ago. I drive about 3000 miles a year and have never had to add oil unless doing freeway driving for several hours. Drove from Columbus Ohio to St Louis and back. Used a quart. Was running 75 most of the time.
      • Paul J.
        • September 9, 2008
        • 2091
        Jack;
        It's coming from the right bank, at least that's where all of the smoke was coming from. Next time you change your plugs you might be able to see if it's any one particular cylinder-2,4,6, or 8.
        Paul
        • Oliver S.
          • December 1, 1999
          • 341
          Is my assumption correct that it is one quarter of oil between add and full?
          Since I have my garage change the oil I don't know this.
          • Tom R.
            • December 20, 2010
            • 177
            I believe it's one quart between add and full.
            • Paul J.
              • September 9, 2008
              • 2091
              Tom is correct, it is one quart between Add and Full, which is what I believe you meant to say. However, I doubt that the measurement on the dipstick is all that accurate.
              Paul
