1958 coil spring compression tool - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    What type of coil spring comression tool works best ? Should I buy the tool that goes inside the spring or one that fits on the outside of the spring?
  • Dan P.
    • December 1, 1990
    • 683
    Re: 1958 coil spring compression tool
    The one that goes on the inside is the best . On a C1 most of the time you can get by with out it.
    • Bruce B.
      • May 31, 1996
      • 2930
      Check out the procedure in the3 ST12.
      No coil spring tool of any kind is needed to remove or install the springs.
      • Dennis C.
        • June 30, 2002
        • 884
        Brandon,
        Search the archives for some good information. A piece of 1/2" threaded rod can be used to compress the spring. It gets installed thru the center of the spring with some blocks on the end.
        Dennis
        • John L.
          • February 1, 2005
          • 207
          Indeed I am in the process of rebuild of the front end of my 1954 and using the 1/2" threaded rod and have not had a problem - but as mentioned it may help with a little piece of mind to have a "safety chain" installed on the coil.
          Good luck!
          John
          • Tom P.
            • April 1, 1980
            • 1814
            Scroll through here until you find it. I put this together over a year ago.
            It will take more time to explain it than it will for you to look at the pictures.
            http://www.chevytalk.org/fusionbb/sh...hp?tid/218134/
            • Dennis C.
              • June 30, 2002
              • 884
              Good luck!
              John
              Absolutely! I used a short wire rope sling and made sure it was secured.
              Dennis
