Change Rear end lubricant- C-2 - NCRS Discussion Boards
  • Herb P.
    • April 19, 2011
    • 37
    What is the best way to change the rear end lubricant on a C-2? Specifically, how does one easily get the old fluid out?
  • Brian M.
    • February 1, 1997
    • 1837
    Re: Change Rear end lubricant- C-2
    I've used a suction gun.
    • Frank E.
      • May 31, 1986
      • 189
      Suction gun. You can buy it anywhere automotive....
      Frank
      1966 Milano Maroon Roadster
      2004 CE Z06
      • Brian M.
        • February 1, 1997
        • 1837
        Most FLAPS will carry them.
        • Gary R.
          • April 1, 1989
          • 1796
          small drill gear pump will work as well.
          • Herb P.
            • April 19, 2011
            • 37
            What is a FLAPS?
            • Robert G.
              • May 31, 1990
              • 429
              Friendly Local Auto Parts Store
              • Kevin N.
                • September 30, 2002
                • 88
                ditto on the suction gun. to make it go alot easier...drive the car for awhile to heat up the old gear lube. it siphons out more easily.
                • Herb P.
                  • April 19, 2011
                  • 37
                  Thanks all. Off to get a suction pump.Might as well take the Vette to warm up the rear end lubricant at the same time.!
                  • Herb P.
                    • April 19, 2011
                    • 37
                    Suction gun, not pump.
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Removing the right rear tire helps when I have done my 68 and 70. I can also lower the left rear without the rear tire on to pool the fluid.
