Cove mounting Washers - NCRS Discussion Boards
  • Roger W.
    • January 29, 2008
    • 564
    The 59 Assembly Manual sect 11 sheet 4.00 shows the side cove molding marked with an X in 5 places. There is a 3723267 washer used in these locations. It looks like some type of fender washer.
    What is the OD of this washer?
    Thanks in advance
    Roger
  • Tom D.
    • September 30, 1981
    • 2126
    Re: Cove mounting Washers
    Roger:
    I have just today written to Paragon about their kits numbered with 954K. I would like them to add these "Xtra" washers in their kits. I am using the smallest fender washer I could find at my local hardware store. They are 3/4 inches O.D., but I suspect 3723267 might be somewhere between 1/2 and 3/4 inches. (Warning: I have no originals to back up my last statement.)
    Note: If you happen to have reproduction front fiberglass, only some of the "X" locations will take this extra washer, due to interference with the wheel wells' inner lip.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Bill M.
      • April 1, 1977
      • 1386
      I bought all the stainless trim and fasteners for my '59 in 1980 from the Chevy dealer and stuck it all on a shelf. It's all still on the shelf. I have a bag of rubber washers in the pile. I'm wondering if that 3723267 might be rubber? It looks like it might be rubber from the drawing in the AIM.
      • Roger W.
        • January 29, 2008
        • 564
        I was hoping that somebody would look at a known original car and give us an answer.
        • Adam S.
          • July 30, 2008
          • 167
          These are Rubber washers, not quite 3/4" , they were used to weather proof the penatrations for mounting studs from trim in fenders & doors. 56 -60 used them. Rubber washers were followed by the flat washer over it , then nut, hope that helps............
          • Roger W.
            • January 29, 2008
            • 564
            That makes sense. I did not think that the large washers would be rubber. I met an owner of a 60 at Harbor Frieght today and I asked him if he knew anything about these washers. He said that they were metal and about 3/4 inch diameter.
            • Bill M.
              • April 1, 1977
              • 1386
              Adam:
              Thanks for the reminder. I knew those were seals (decades ago), but had forgotten.
              Bill
