I was wondering if those of you that have installed these windshields (69 in my case) could give me some advice or tips to help with the install and make it look proper.
I realize that buytal tape is out so I bought two tubes of urethane from a glass place so I should be good there.
I have a damming strip but it's not an original type so I'm not sure if I should use it anyways or go without...
One big issue I can see is getting the glass to sit at the right height so that the trim fits properly. The windshield that was in it was about .250" thick but the repop one is only .200" thick. Not that it matters much because the windshield had been replaced before and the rubber blocks/spacers were never reinstalled... So what's a good way to get this height set right?
As always, thanks guys!
