Removing Pointers on gauges. - NCRS Discussion Boards
  • Keith M.
    • November 1, 1976
    • 205
    If I remove the pointers from the gauges how will I know where to put pointers so they will read correctly?
    Thanks for your input and ideas.
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: Removing Pointers on gauges.
    Note the position of the pointer on the gauge before removing and reinstall at the same point.
    • Russ S.
      • April 30, 1982
      • 2161
      I would think that there would be some tension on the pointer resting on it's peg that when removed would allow the shaft to rotate in which case this wouldn't work.
      • Brian T.
        • September 30, 1990
        • 188
        the only gauge that will work with, reliably, is the batt gauge.
        • Keith M.
          • November 1, 1976
          • 205
          Thanks Brian.
          • Keith M.
            • November 1, 1976
            • 205
            Thanks Russ.
            • Keith M.
              • November 1, 1976
              • 205
              Thanks Steve.
              • Doug F.
                • November 1, 1983
                • 322
                When i need to get one of my pointers off of a gauge i just use a firm but authoritative voice and say " NO, Bad dog " usually works, but seriously, back in the days when you couldn't get the right temp sender, we would set up a complete working gauge and sender on the bench with a pan of hot water and a candy thermometer and put the needle back on at the correct corresponding position, that method had its drawbacks but worked somewhat well, you could do the same with the fuel gauge, the oil and amp just get set to 0, be careful not to touch any wires where they don't belong or it gets expensive.
                • Keith M.
                  • November 1, 1976
                  • 205
                  Doug,
                  I knew there was someone out there that had gone down this road before.
                  From the looks of your dogs are you a bird hunter?
                  Keith Majure
                  • Doug F.
                    • November 1, 1983
                    • 322
                    Keith,
                    Yes, i chase birds every chance i get, spent a couple of weeks in Montana recently, waiting for the snakes to go to bed so we can run after the quail here in Arizona, hope your gauges worked out ok.
                    • Keith M.
                      • November 1, 1976
                      • 205
                      Doug,
                      Where did you go in Montana? I have been to Froyd to hunt chukas several times over the years. Will be going to Kansas the week of Thanksgiving to pheasant hunt. I Use to do my quail hunting in Texas but it looks as if that is history for the time being.
                      You must be in pretty good shape to hunt behind those Pointers. If I hunted behind them I would be dead. I have to hunt behind short legged Brittany's.
                      I worked on 63 seats this evening. It loooks as if I have put the cluster project off for a while.
                      Drop me an email at kmajure@bellsouth.net and keep me posted on the bird hunting activities.
                      Keith Majure
