54 drag link install - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Has anyone had trouble tightning the link at 3rd arm. I cant seem to tighten it down far enough to get the cotter pin in. s12 says take out the slack and back it off but it seems bottomed out. I carefull took a hammer to it to see if its positioned correctly and it is. I really only need one more turn. Any suggestions? Thanks as usual!!
  • Erich C.
    • January 31, 2007
    • 137
    Re: 54 drag link install
    Maybe the ball seat rotated out of its groove as you were turning the adjuster screw. If it did you would lose about 1/4" or less of adjustment.
    • Guy M.
      • November 1, 1993
      • 499
      Thanks Erich, something was screwie in there but I got it. Thanks to everyone who has helped me through your posts. #2468 will breath again next Monday for the first time in over 40 years, shes full of fluids, oil pump primed. Ill let you know if it pukes on me. ( chasis only ) The rest of it is getting a face lift, tummy tuck, bow tocs.....whatever
      • Brett H.
        • January 1, 1996
        • 367
        Glad you got it tightened. I normally grease the inner assembly really well to avoid the issue. Works alot better.
        Brett
