1960 Radiator Support Seals - NCRS Discussion Boards
  • Joe M.
    • April 30, 1990
    • 1338
    I figured out where to glue the corner pieces, but the long piece does not seem to be wide enough to fill the gap between the bottom of the radiator and the radiator support.
    Where do I glue the long piece on the radiator support and how much gap should remain between the bottom of the radiator and the top of the rubber seal?
    I estimate there will be at least 1 inch gap depending on where I glue it. Is my repro radiator shorter than the original?
    I attached a photo of the gap without a seal.
