Can anyone clear this up. Have what appears to be the orig 915 dist. Vacume advance is HEX and oiling is by engine oil via tube. Aim shows has tube with flip lid like passanger car??? thanks RDR
58 250 hp fi PG dist. oiling
Re: 58 250 hp fi PG dist. oiling
'915 and '914 oil the same way, via pressure feed at the rear of the block. AIM drawings are not representative of actual parts in many cases.Bill Clupper #618- Top
Ronald -
Photo on page 317 of Colvin's CBTN book shows a 915, made in October of '57, and it has an oiling tube for the upper section and a hex vacuum advance. Accompanying GM drawings of the 908 and 914 centrifugal-only distributors don't show an oiling tube. The fuel pump drive gearbox on all three is pressure-lubricated.- Top
Ron, The 915 has a separate oil tube on it with a flip top cap. Configuration of the tube is important as so many of the car distributors had those tubes in the 50's, etc.
O
First of all every 57 to 65 FI distributor was fed engine oil (not a grease fitting) via a distributor oil line assembly consisting of various fittings and the 3/16 steel oil line.
Original T fittings for this oil line kit are much thinner than todays T fittings. In fact most all of the old time original fittings for this kit/assembly are a small OD than whats available today. But you didn't ask this.
Recap: 915 had the usual distributor oil line and also a curved tube with a flip top cap to it.
The hardest thing about restoring a 915 today is getting an original hex vacuum advance. Another difficult item is figuring out what is correct for the vacuum line from the distributor to the FI unit. Power glides used a different setup that std trans cars.
The 915 is single points and has no provision to drive a tach. The low HP FI's tachometer was run by the generator. John- Top
