High oil pressure - NCRS Discussion Boards
High oil pressure
  • Joe C.
    • August 31, 1999
    • 4598
    #31
    Re: High oil pressure
    Many moons ago, a wise old Indian by the name of Smokey Yunick, told me that 10# oil pressure for each 1,000 rpms was adequate for a race engine. Todays race engines, with the modern lubricants require quite a bit less than to to safely operate.
    High pressure and high volume oil pumps in street engines today fall in the catagory of "Snake Oil" remedys.
    I agree. The 10 psig/1000RPM rule seems to be the accepted guideline. Pressure will also be very dependent on journal to bearing clearance.
    • Domenic T.
      • January 29, 2010
      • 2452
      #32
      Originally posted by Joe Ciaravino (32899)
      Were the main journals align honed? If your crank is small journal, then your bearing clearance should be .0021 +\- .0005. If the clearance here is on the small end of the range, your oil pressure will be on the high side.
      You should be using Rotella in 10W-30 preferably, if not, then 15W-40.
      The oil pump should have nothing to do with idle pressure when at operating temp since the high pressure pump relieves at 65-70psig and the standard pressure spring relieves at 55-60psig.
      Actually,
      Each different spring has a different low and high pressure, at all temps.
      It would be nice that way but there is only a limited space for the spring in the pump.
      So a stiff spring restricts the oil from bi-pass also at idle and is at full bi-pass only when fully opened.
      DOM
      • Dick W.
        • 10483
        #33
        Wondering about the Renault F1 engine that turns 19,000 rpms. Rule probably does not hold true in modern racing engines.
        Dick Whittington
