For a '69, can someone tell me how to tell reproductions from originals?
3X2 Fuel line brass T-blocks
Re: 3X2 Fuel line brass T-blocks
Originals have a "W" repeated on the blocks- repos do not. USA corvettes - advertised in Drive line has originals.
Pat- Top
This is the Weatherhead logo. I have seen some repros with just a plain W on them.
Sorry about the quality of the photo, when I enlarged it, I found it was slightly out of focus.Dick Whittington- Top
Dick -- here's 2 shots off a late '69 fuel block. The second junction block was so faint all you could see was the outside imprint of one side of the row of hexagons.- Top
Same logo on the ones I have as well. I also noticed the same logo on the brake line blocks.- Top
The W, with the arrow thru it, inside the octagon pretty much seals the real dealDick Whittington- Top
- Top
as long as you don't use stainless steel lines because if the flare is not correct it will eat into the brass fitting and maybe leak. with SS lines i used a steel fitting to preform the line flare before installing it in the brass fitting and this may be a good idea even with plain steel lines- Top
holley carb center pivot float bowls use a steel inverted flare fitting for the fuel line and i use one of those held in a bench vise to tighten the line into to form the flare on the line before putting them in to a brass fitting.- Top
I know that fitting should be steel, and on many of the 1969 & 1970 Holleys I have seen it is plated black -- but that picture sure looks like brass.
Terry- Top
