What spark plug for a '65 327ci, 350 hp? - NCRS Discussion Boards
  • Edward L.
    Infrequent User
    • July 31, 2001
    • 7
    Any help, I know the AC Delco 44 is the correct plug but can't find it locally, any suggestions on a sub?
    Thanks ED
  • William C.
    • July 15, 2009
    • 239
    Re: What spark plug for a '65 327ci, 350 hp?
    Edward..There is a set of AC44 on EBAY for $40. I'm running R45 in my L79. They are 1 heat range hotter than 44's, but for normal driving there fine...Bill
    • Edward L.
      Infrequent User
      • July 31, 2001
      • 7
      Any other brands that would be equal the AC Delco 44?
      • Jim T.
        • March 1, 1993
        • 5351
        I have used RJ12Y Champion spark plugs in my 68 327 350HP for over 30 years.
        • Edward L.
          Infrequent User
          • July 31, 2001
          • 7
          Is that run the same heat range as the 44?
          • Jim T.
            • March 1, 1993
            • 5351
            Do not know about heat range, also use the same Champions in my 1970 350/300.
              • 43193
              Edward------
              The RJ12YC (RJ12Y is no longer available) is equivalent to the AC R44S. The R44S is an extended tip version of the R44. I would highly recommend the Champion RJ12YC for your application.
              If you want the exact equivalent of the R44, then use the Champion RJ8C.
              • Louis T.
                • July 31, 2003
                • 282
                Hi Edward,
                I follow DukeMay 9th, 2011:
                Even at high cruise speed, all Corvette engines are operating under relatively low load, so they can get away with relatively hot plugs that will stay clean in low speed driving.
                Good luck,
                Louis
                • Dennis O.
                  • December 1, 1988
                  • 438
                  I agree with the Denso W14-U as well. I was having troubles with the AC R44S (extended tip resistor plugs) running too cold on my '67 L79 (When I pulled them, they were black, not brownish tan), so I switched to the Densos (non-resistor) and have been very happy. An additional advantage. I found them on eBay for $1.10 each (shipping included!). The prices for original AC 44's I found were ridiculous, and AC 45's seem to be made of unobtainium.
                  • Michael M.
                    • February 1, 1993
                    • 603
                    Edward, your choices are AC R 45TS, Bosch (old) WA 145 T30, Bosch (new) HR 8Y, Champion RBL 15Y, Fram/Autolite 415, Mopar P-62 PR, Motorcraft BRF-42, NGK BP 5ES-15, Nippondenso W 16 EP, and Prestolite 14GR 5 2A. The recommended heat range and what you use is up to you. Hope this helps.
                      • 43193
                      Michael-----
                      I believe that an AC R-45TS is an extended reach, TAPERED SEAT spark plug. If so, it won't work for a 1966 application which all used gasketed type plugs.
                      • Donald T.
                        • September 30, 2002
                        • 1319
                        I've been running AC R45 in my 65 L79 for years and they are fine for normal driving. If you REALLY want the correct AC 44, they can be found occassionaly on ebay. Also, the AC R44 would be the resistor version of the same plug and they are cheaper and more plentiful on ebay.
                        • Stuart F.
                          • August 31, 1996
                          • 4676
                          Being old school, I have been running the same set of AC 44's in my 63 L-76 SHP for the last 10 years. But, of course, we're only looking at maybe 6,000 or 7,000 miles, and it's not as if they age. The engine will still hit redline with ease if I don't "self impose" my 5500 RPM rev limit. I expect that is because of my Pertronix coinversion which has made frequent plug changes a thing of the past (for me). It is getting about time to make a change only because I am afraid they (the AC's) will rust into the heads. With this thread bringing up the subject, I went out to check my old stock and here's what I have;
                          (1) set AC45S "Fire Ring"
                          (1) set AC45 "Fire Ring"
                          (2) sets AC R43's
                          (2) sets Champion J-12-Y's
                          (1) set Champion N-12-Y
                          Now then, can anyone tell me which would be the better choice given the knowledge that my engine lives well with the AC44 heat range. Also, those N-12-Y plugs look suspiciously like "long reach" plugs for either a "W" engine or a big block - both of which I worked on a lot back in the day, but my old memory fails me and most of my 3" x 5" card records areonly about Carburetors and Distributors.
                          Stu Fox
                            • 43193
                            (2) sets AC R43's
                            Stu Fox
                            Stu------
                            The N12Y plugs are for big block applications, not small block.
                            • Timothy B.
                              • April 30, 1983
                              • 5177
                              Stu,
                              If the color on the AC 44's looks good I would leave them..
