Current Corvette Restorer has an article on rebuilding the the rear spring on a C2/C3 which appears to be a starightforward process. Does one have to be concerned with the steel itself being spent, i.e. no longer having the correct spring rate if you will? In which case it would not be worthwhile investing the time to make it look good.
Jack
Jack
