54 water pump bolt leaking - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    The bolt that threads into the water jacket needs a sealant, what do you folks use? Blue locktight?
  • Paul J.
    • September 9, 2008
    • 2091
    Re: 54 water pump bolt leaking
    Permatex Thread Sealant or any other high quality thread sealant.
    I've seen people use lock tight for a sealant, but I do not believe that it is not intended for that purpose.
    • Dick W.
      • 10483
      Loctite Blue is not intended for a sealant. As Paul said, Permatex or Loctite (owned by the same company) have a thread sealant with Teflon. Loctite calls it Pipe Sealant with Teflon.
      Dick Whittington
      • Guy M.
        • November 1, 1993
        • 499
        Thanks Guys, you have been most helpful
