54 water pump base gasket - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Shoud the gasket completely cover the two holes where the passanger car pump would utilize? The gasket isnt cut fot it. The freeze plug is out and I want to be sure if the gasket can cover the two holes or should the gasket be cut. This is a 54 passenger car block retrofitted. Thanks folks!!!
