62 extra ground on valve cover - NCRS Discussion Boards
  • Brian B.
    Infrequent User
    • November 22, 2010
    • 20
    I have an extra (3rd ) ground wire on my passenger side valve cover. One goes to the wiper motor mount , another to the radio . I believe these are ok. The other one goes to a screw on the heater blower in the passenger side under the dash. Is this original , or did someone add this for reliability. If so , how should the heater be grounded.
    Thanks ..
    Re: 62 extra ground on valve cover
    Thanks ..
    Brian -
    That's a common modification to ensure a good ground for the heater blower. The production ground is through the sheath of the temp cable to the back side of the console plate, which is flaky at best.
