Question 1: Does anyone have a photo of the correct orientation of the french locks that hold the 1/2 shaft bolts to the outer flange? My AIM shows each of them attaching as shown in the first attached photo. However, all of my parts catalogs as well as photos of Bloomington cars and David Burroughs', "Art of Restoration" car show them attaching as shown on the 2nd and 3rd photo. Which way is correct?????? Picture the U shape at the outer end of the 1/2 shaft as a football goal post. Do the french locks span across the opening of the football goal post as if kicking a field goal that is GOOD? Or, do the french locks span across the clips on the outer edges of the U shaped/football goal post? Hope my question makes sense!
Question 2: Any tricks I am missing in order to keep french locks from bending totally out of shape while trying to torque bolts to 60-90 ft. lbs? I tried using anti-seize between the bolt head and the lock....this helped but they still bent around 50 ft. lbs. of torque.
I have the thin steel 63-64 french locks....no good.....keep bending. I decided to order from Paragon the 65 and later stainless steel locks that have the arched ribs in them to help keep them from bending and rusting. I know they are not correct for a 1964 but I'm tired of my 64 locks bending totally out of shape.
