'61 heater fresh air hose clamps - NCRS Discussion Boards
  • Charles C.
    • May 31, 1978
    • 65
    I need help on the correct clamps used on the heater hose (runs from the radiator area to the heater core) for a '61 Vette with Fuel Injection.
    The assembly manual shows the heater hose clamps as the style with the tighting screw at a right angle to radial but the Corvette Central shows the clamp as the style with the tighting screw radial (perpendicular to the arc of the band).
    Which is correct?
    Thanks.
    Charles
  • Terry D.
    • May 31, 1987
    • 2690
    Re: '61 heater fresh air hose clamps
    Does the Judging Manual tell you which? Jusy because a vendor sells it don't assume it is correct.
    • Charles C.
      • May 31, 1978
      • 65
      I don't see that the judging manual specifies which.
      • Scott K.
        • February 1, 1980
        • 59
        The first two photos feature our P/N 451210 1956-60 clamp. This one threads through the slot, bends back 180 degrees and the screw just keeps it from unbending.
        Third and fourth pictures are our P/N 451211 1961-62 clamp.
        *EDIT: Apologies for the huge first image. I can't seem to save changes after resizing it. Maybe the moderator can assist.
        Corvette Central
        800-345-4122
        www.corvettecentral.com
