I picked up an NOS December 10, 1970 dated short block in the original crate last week and I thought I would post some pictures of the markings on it and paint inspection marks. I can find a lightly stamped CE on the pad that is very faint.
1970-71 Nos Lt1
Re: 1970-71 Nos Lt1
Here is a couple more. Can anyone tell me what these inspection marks mean on the block?It's a good life!
- Top
Re: 1970-71 Nos Lt1
Paul,
I can't help with the markings but that is a very nice piece.. Where did you find the motor..
- Top
Re: 1970-71 Nos Lt1
The crayon marks on the block may be from inspectors, and/or ID this job to receive the LT-1 crankshaft, however, the block is othewise identifiable because I think it was the only '70 SB machined for four bolt main caps.
The "H" on the piston is probably the size group and there should be some codes underneath to indicate the piston size for each cylinder. The pistons were installed with the block upside down. There were about four piston size groups, and one was selected based on bore measurement for each cylinder.
John Hinckley can probably provide more info.
Is the cam sprocket nylon-tooth or steel-tooth?
Duke- Top
Re: 1970-71 Nos Lt1
Paul------
This is a 1971-72 LT-1 short block, not also applicable to 1970. Note the piston crowns. This style crown is the 9.0:1 CR used for 1971-72 but not 1970.In Appreciation of John Hinckley- Top
Re: 1970-71 Nos Lt1
Duke-----
All 1970-72 LT-1 were equipped with 4 bolt main caps.
If the installed camshaft sprocket is anything other than nylon-toothed aluminum I'll be amazed.In Appreciation of John Hinckley- Top
Re: 1970-71 Nos Lt1
I had a genuine NOS 1970 LT-1 short block a couple of years ago. It did not have any marking on it.- Top
Re: 1970-71 Nos Lt1
I believe other small blocks used 4 bolt main caps as well, not just LT-1's, I'd expect to see the same on my L-46. Steve- Top
Re: 1970-71 Nos Lt1
The cylinder bore size codes were stamped on the oil pan rail while the case was upside down. I don't know what those codes were -- numbers or letters -- but they air-gauged the bore and lights on the machine told the operator what character to stamp on the rail near that bore. I would expect ALL small blocks from Flint to have these bore size stamps, and I would not be surprised that Tonawanda used a similar process.The "H" on the piston is probably the size group and there should be some codes underneath to indicate the piston size for each cylinder. The pistons were installed with the block upside down. There were about four piston size groups, and one was selected based on bore measurement for each cylinder.
Duke, I believe truck small blocks of this period also used four-bolt main bearing caps.Terry- Top
Re: 1970-71 Nos Lt1
Steve-----
I did not say that other small blocks of the period did not use 4 bolt mains; I simply stated that all 1970-72 LT-1's were equipped with 4 bolt mains.
For 1969-70, all Corvette small blocks, base engine to LT-1, were equipped with 4 bolt mains. For the 71-72 period, some base engines may have been originally built with 4 bolt mains and some not.In Appreciation of John Hinckley- Top
Re: 1970-71 Nos Lt1
Tim, Thank you. I found it in a sub division of Denver on the local craigslist. It had been in the seller garage since the 70's sometime. It came from Burt Chevrolet, known as a high performance parts dealership.It's a good life!
- Top
Re: 1970-71 Nos Lt1
Duke, the cam sprocket is nylon toothed.Attached FilesIt's a good life!
- Top
Re: 1970-71 Nos Lt1
Paul-----
Sort blocks for SERVICE were produced for 1970 LT-1 applications as late as 1975. So, the cast date of the short block does not imply whether it's for a 1970 or later LT-1. It's the short block assembly PART NUMBER that identifies it as well as features like piston configuration.
The 186 head would up the compression ratio of this short block to ABOUT 10:1.In Appreciation of John Hinckley- Top
