The driver's side door does not line up with the rear body (sets too low) when the body centerline of the door and rear body are aligned (photo #2). I have seen this same situation on other midyears, but not consistently. When we stripped the paint, the area in question had been "built up" with filler in order to "match" the rear of the body. When the filler was removed, there was NO damage underneath, it was just to make the door "look" right. It's possible that many other driver side doors have been modified in the same way over the years for a better fit, which would explain the inconsistency from car to car.
The passenger door (no filler) matches the body perfectly, the problem is only with the LH door.
1st photo shows the misalignment at the top, the other photos show that the door is otherwise correctly aligned.
Is this "step-down" from the rear body to the top-rear of the LH door "typical factory production", the result of a problem with the original manufacturing process? What did the factory do in this situation?
