Warning: Undefined array key "scheme" in .../vb/api/content/link.php on line 542 Warning: Undefined array key "host" in .../vb/api/content/link.php on line 542 75-77 Judging Manual - NCRS Discussion Boards
  • Marv S.
    Infrequent User
    • May 31, 1979
    • 8
    Need a little help with the change on water pumps & gas caps, view attachments.
    Marv Stober 2500
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 75-77 Judging Manual
    Ref. the water pump, I'm not sure that the numbers are accessible at all.
    The plug mentioned is installed on top of the pump and otherwise served as the location for a bypass port- obviously used on your year. I believe OEM pumps for Corvettes used a female plug as seen in this link shamelessy borrowed from Pat Hulst's album.
    Webshots, the best in Desktop Wallpaper, Desktop Backgrounds, and Screen Savers since 1995.
    Aftermarket/rebuilder pumps frequently use a male plug with a protruding square plug.
    • Tom R.
      • June 30, 1993
      • 4081
      Marv Stober 2500
      Marv
      I take it your question pertains to the part number listed in the manual versus that in the AIM and on your vehicle. Two points to be made regarding unleaded fuel caps. Note that the manual in its 2nd edition was last updated in 2000 and there is much that needs to be updated and so your observations are on target.
      We had a discussion on the topic a couple of years ago and I've included the link below. But the conclusion was that there were a number of caps used during the unleaded fuel cap formative years. The GM# 419862 was an early cap design but its usage unknown while the GM #559346 was a later design that carried over into the late C3 years including the 77 year.
      https://www.forums.ncrs.org/showthre...+caps&uid=4296
      The 77 cap shown are among those known to have been shipped from the St Louis assembly plants and the ear is a feature of the "first" design for unleaded fuel caps. The date code 225 6 would have seen service on a 77...which the caption on your photo indicates. Is this cap original to a 1977 Corvette?
      Tom Russo
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • Loren L.
        • April 30, 1976
        • 4104
        Marv, just tell Jan "It's your car, work on it.".
        • Michael W.
          • April 1, 1997
          • 4290
          The plug mentioned is installed on top of the pump and otherwise served as the location for a bypass port- obviously not used on your year. I believe OEM pumps for Corvettes used a female plug as seen in this link shamelessy borrowed from Pat Hulst's album.
          I can't edit my post above but realize I left the word 'not' out with regards to the plug. Text above is correct.
          • Marv S.
            Infrequent User
            • May 31, 1979
            • 8
            Hi Loren, How's every thing. I once gave Jan a wrench to use & she said it was too small to drive nails.
