A buddy of mine just showed me a picture of a rat rod with what he was told by the owner it was a late 1930's six cylinder motor from a two ton truck. This motor had two distributors and twelve spark plugs. Did Chevy ever make such a critter? Thanks in advance.
Non Corvette Question
Re: Non Corvette Question
Jerry,
With out a picture it's hard to ID, but I don't think chevrolet 6 cylinder engines ever had 12 plugs and 2 distributors.
BUT,
Aircraft engines did have dual ignition systems and plugs.
I have a 6 cylinder, dual distributor, 12 plug blimp engine from 1914. The later engines mostly had dual magneto's.
Sounds like a aircraft engine to me and I have seen them at the strip back n the 60's.
DOM- Top
Jerry,
BUT,
DOM
Here's the first "Green Monster" Art Arfons built, which most people have never seen - I took the photo at the Akron dragstrip in 1957. It had a 6-cylinder Ranger aircraft engine, mounted inverted as it was in airplanes, with dual magnetos; note the primary chain drive sprocket, right next to your head.Attached Files- Top
John,
Nice picture, I thought it was going to be the jet he ran as the green monster.
I saw it run at US 30 dragstrip (Indiana) back in the 60's.
I didn't know he had more GREEN MONSTERS untill I saw your picture.
DOM- Top
Attached Files- Top
I also saw the Allison run back then and if I remember they had 2 linked together and only one made it thru the 1/4 mile.
The RPM's were very low and still are in the gas recip engines so they must have had a tall gear.
Some of the old radials ran about 1500 rpm's at cruse settings and most today in the flat engines are 2700 rpm's & below.
I guess they were thinking all bottom end when they ran them at the strip.
DOM- Top
John,
Did he run the dual allison dragster or was it someone else. I saw one run in the early 60's around the same time I saw the jet dragster he had.
DOM- Top
A buddy of mine just showed me a picture of a rat rod with what he was told by the owner it was a late 1930's six cylinder motor from a two ton truck. This motor had two distributors and twelve spark plugs. Did Chevy ever make such a critter? Thanks in advance.- Top
National Fire Codes at one time required dual ignition on class A pumpers. My guess it that he has a Waukesha, Continental, or Hercules engine. They were predominant engine suppliers for the fire serviceDick Whittington- Top
- Top
