Re: Distributor Hold Down Bracket - 1960
John------
Not just 55, 56, and 57. According to GM the GM #3704912 clamp was used for all 55-59 small block as well as all 1968-79. The 1968-79 version of it is as I have pictured. That version may also have been used in the later 50's but I don't know one way or the other on that. Maybe there were even more than 2 versions. Why the part number was not changed when the clamp changed significantly I do not understand.
For 1980 the clamp was changed to GM #14007385 which also became SERVICE for all 1955-79. The 14007385 is pictured in the middle of the photo I posted in December, 2008. Note that it is only very slightly different than the 3704912. However, in this case the very slight change resulted in a new part number. This is the norm.
John------
