With the key on, the temperature guage needle sets on the left hand side as it should be. As the engine warms up the needle starts moving to the right as it should. after few minutes the needle moves all the way over to red. After about 10 minutes the needle returns to left of center where it should be. I am not sure what could cause this to happen. It appears like the thermostat is slow to open, however I am not sure that this is the case. Before I start replacing everything to do with the temp guage I would like to know if anyone has had a similiar problem and how did they fixed it.
Thanks for any feedback.
Rod
Rod
